Zenith CruZer & Sonex Logs
Date:  10-7-2009
Number of Hours:  0.70
Manual Reference:  SNX-F08
Brief Description:  Fabricate SNX-F08-12 Trim Cable Angle
Made two parts because I wasn't satisfied with the first.
Cut .032 stock to the pattern shape as per plans. Drilled an 11/64" hole and a 3/16" hole, bent the stock to 90 degrees. Cable will go thru 3/16" hole on its way to the trim lever; the 11/64" hole is for the cable restraint clip. Frustrating week.
