Zenith CruZer & Sonex Logs
Date:  6-12-2009
Number of Hours:  1.80
Manual Reference:  SNX-F14
Brief Description:  Fwd Fuse Parts
Took time; doesn't seem like a lot was completed.
Up-drilled the rudder pedal block supports to #30. Countersunk the 3 rivet holes in each to take CCC-44 rivets. Deburred. Riveted both assys.
Dug out parts for other SNX-F14 parts; notably the cowl attach hinge assembly. Located, measured and cut the -P4 hinge (most other is -P3); angled each end, and removed the lower two lugs as per plans. Cut SNX-F02-03 angle stock to length. Ripped one side to 3/4" width; other "leg" is to be the width of the hinge.
Note: Plans specify -P4 hinge, which is about 5/8" wide, as opposed to the 1/2" width of -P3 hinge. Yet the channel stock is to be close to 1/2" wide on the leg I have yet to cut. Fast-forwarding ahead to SNX-F12, it doesn't appear to have any impact once it gets located and riveted to the forward edge of the fwd fuse skin, but the rivet holes will be at an unstandard location.
Rudder Pedal Block Supports
Cowl Attach Hinge Assy
