Zenith CruZer & Sonex Logs
Date:  3-24-2012
Number of Hours:  3.00
Manual Reference:  n/a
Brief Description:  More Wing Polishing
Tedious work polishing the right wing in preparation for mounting the wingtips.
As a reminder, since the wingtips are painted, I didn't want to be polising the metal of the wing right up against the wingtip. So, I polished each end of the wing (the inboard side just to make it easier to polish up against the fuselage).
I also polished the underside of each wing. Only used the "F" grade NuVite because no one will really notice when it's in the air. It was also easier to do it on sawhorses instead of flat-backin' it.
I had done the underside of the left wing a few days ago; just didn't register it on the website.
Wingtip
Wingtip
Cockpit End
Cockpit End
Wing Bottom
Wing Bottom
