Zenith CruZer & Sonex Logs
Date:  1-16-2012
Manual Reference:  n/a
Brief Description:  Placards / Canopy Cable / Painting Turtledeck Form
First off, I called Rustoleum Tech Support today to find out about the clearcoat wrinkling on the right wingtip (yet again). He asked how long I waited to sand it (2 days), and then how long I waited after sanding before clear-coating. Hmmmm... Never had that question before. He said after sanding, allow 2 days before painting again to allow time for the paint to outgas after scuffing the surface. Makes sense; we'll see what happens when I try it that way.
On another paint issue, I was moving about the shop and knocked the left wingtip (the good one) onto the floor, putting 3 one-eight dings in the edge. *sigh*
So, today, I finished installing the final placards in the cockpit (I had run out of labeller tape prior). I also received and installed the *engraved* passenger warning placard. I had to trim-off one corner where it was a bit longer than the adhesive version that came with the EAA registration kit.
I still had some time left, so I figured I'd paint the turtledeck formers. Spent quite a bit of time masking-off the stuff I didn't want to get covered with paint. Sanded the formers and shot them with primer. Now to wait 48 hrs before first color coat.
Placards Finished
Placards Finished
New Warning Placard
New Warning Placard
Masked & Sanded
Masked & Sanded
