Zenith CruZer & Sonex Logs
Date:  1-26-2010
Number of Hours:  0.80
Manual Reference:  various
Brief Description:  Misc Items
Just futzed around the shop tonight; received some fresh supplies from Jegs (fuel line and fittings) and Wicks (AN hardware, bungee cords, other fittings), so put them away. Played around with some of them to make sure they fit as they should.
Swapped out the AN4-15 bolts holding the secondary ignition coils with AN4-16 bolts; the -15's were just a tad too short, and did not have enough threads showing on the backside of the nutplates.
Re-tested the mixture cable "fit" against the bottom of the panel cross-member. It's tight, but I think I'll use it as-is. Will be relatively simple to remove 8 rivets if I ever have to remove the cable.
