Brief Description: Left Wing Hinges & Spar Up-drill
Cut aileron and flap hinge halves for left wing.
Up-drilled lower leading edge side of root doubler.
Up-drilled lower main spar & skins to #30.
Dug out SNX-W18 access hole cover from parts box.
Remaining tasks for left wing box: remove LE skin; deburr, dimple skin & ribs. Pilot drill aileron & flap hinge halves to wing box. Remove upper aft skin, pilot and up-drill the aileron bellcrank stiffener brackets to the lower skin. Deburr everything else and rivet.
Still haven't decided if I want to install the Duckworks landing light. I'd better decide quickly!
