Zenith CruZer & Sonex Logs
Sonex
03 - Wings
12-26-2008
SNX-W14
Left Root Rib Rivet & Up-Drilling Ribs
Riveted Fwd / Aft left wing root ribs to attach angles.
Up-drilled fwd/aft left wing ribs to #30 thru main spar.
Next steps: Remove ribs, deburr all. Deburr main spar. Bolt root rib halfs to main spar, rivet ribs to main spar, then rivet aft spar to ribs.
Riveted Root Ribs
Ribs Up-Drilled to #30
Overall Shot of Up-Drilled Ribs
750 Cruzer Home
Sonex Home
2664
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
219
02 - Wing Spars
03 - Wings
119
389
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
219
Systems
389
