Zenith CruZer & Sonex Logs
Sonex
03 - Wings
12-10-2008
SNX-W15
Left Wing Rib 1 & 4 Rework
Drilled 1/4" radius holes in each of the ribs; trimmed flange material away as per plans to clear the main spar caps.
Deburred.
Positioned, drilled, and cleco'd all 4 rib gussets.
Next up: up-drill to #30, deburr, and rivet gussets to ribs.
This will complete the rib rework.
750 Cruzer Home
Sonex Home
2664
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
219
02 - Wing Spars
03 - Wings
119
389
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
219
Systems
389
