Brief Description: Right Wing Aileron Hinge Initial Fit
Measured and cut the aileron hinge halves. Marked the centerline. Clamped into position and pilot drilled to #40. Went back over it and up-drilled to #30 and cleco'd.
At this point, just have to fit the control rods to the aileron bellcrank (easier before skinning), remove the skins to deburr, then rivet. FINALLY!
Hinge Fitted
Shot Showing 0.5" offset from Flap to Aileron Hinge
