Zenith CruZer & Sonex Logs
Sonex
03 - Wings
10-4-2008
SNX-W07
Right Wing Lower Aft Skin Fitting
Positioned and levelled / checked square of right wing after positioning upper aft skin and flipping over the wing.
Positioned, drilled, cleco'd the aft spar row of pilot holes, then moved forward from the center of the wing.
Drilled all pilot holes in the main spar extrusion cap.
Next up: leading edge skin
Drilled / Cleco'd Lower Aft Skin
750 Cruzer Home
Sonex Home
2664
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
219
02 - Wing Spars
03 - Wings
119
389
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
219
Systems
389
