Not much real work accomplished today. Mostly pre-positioned parts like the elevator control horn and the elevators in relation to the horizontal stabilizer to see if things would line up preliminarily. All looked good, all things considered. It looks like the right elevator skin that is cut a bit short will still fit well and within specs of SNX-T02 drawing. Only minor issue is that the elevator hinge assembly that fastens to the aft spar of the stabilizer (for the right elevator) will have one rivet that is not going to have 1/4" from the edge because of the overall shorter length of the elevator by 1/16". Given there are ~33 other rivets, I don't believe this will be an issue.
