Zenith CruZer & Sonex Logs
Date:  1-31-2009
Number of Hours:  2.40
Manual Reference:  SNX-W07
Brief Description:  FINISHED Left Wing Box
Riveted Leading Edge of Left wing. Not much to say; just the tedium of a few hundred rivets.
Messed up two of the flush rivets on the bottom of the wing around rib 10. Had to drill out, but they wanted to spin a bit. Took my time, and got close enough where a pair of small dykes were able to finish snipping the head.
Also had to grind down a few mandrels that broke off slightly above the surface of the rivet. A grinding stone in my Dremel tool made short work of that.
Wing Boxes, both left and right, plus spar work were started about 1 August upon my return from AirVenture. Took 6 months total, but we were gone a bit in the fall. Missed a full week around Thanksgiving, and the early part of the Christmas break also took some time away from the project.
Bottom of Left Wing
Bottom of Left Wing
Top Surface of Left Wing
