Zenith CruZer & Sonex Logs
Date: 12-9-2008
Number of Hours: 1.00
Manual Reference: SNX-W15
Brief Description: Left Wing Fwd Rib Rework
Started on the left wing. Well, actually, performed rework on parts I messed up a few months ago, in preparation for using them on the left wing.
I had previously run out of .125" x 0.5" bar stock with which to make the rib spacer blocks that go in between the upper/lower spar caps. I obtained some scrap stock from another builder (Thanks, Dick!), so cut it to size and marked the centerline tonight.
Also bent SNX-W15-06/07 rib gussets that were replacement parts purchased from Sonex after I messed up fwd ribs #1 & #4 a few months ago.
Lastly, marked the new replacement ribs 1 & 4 for trimming to fit the spar caps.
Basically, to finish the left wing, all I have to do is finish up these rework ribs, construct the #9 aft rib supports for the aileron bellcrank, and trim the fore/aft root ribs. Then cleco the ribs to the main and aft spar, square the aft spar in relation to wing station 0,0, position, drill, and cleco the root rib, then start riveting.
Reworked Details
Copyright © 2001-2020 Matronics. All Rights Reserved. |
