Zenith CruZer & Sonex Logs
Date:  10-4-2008
Number of Hours:  4.20
Manual Reference:  SNX-W07
Brief Description:  Right Wing Lower Aft Skin Fitting
Positioned and levelled / checked square of right wing after positioning upper aft skin and flipping over the wing.
Positioned, drilled, cleco'd the aft spar row of pilot holes, then moved forward from the center of the wing.
Drilled all pilot holes in the main spar extrusion cap.
Next up: leading edge skin
Drilled / Cleco'd Lower Aft Skin
