Brief Description: Rigged Control Surfaces; Mod'd seat pan
Adjusted the aileron pushrods as per spec. Was in Hawaii last week hence the delay in accomplishing anything.
Enlarged the control stick holes in the seat pan; full aft control deflection was liimited, not to mention the scraping of the stick on the pan, rubbing away the powder coating. Hole was mostly a triangle shape. I just extended the lower portion by 7/8".
