Zenith CruZer & Sonex Logs
Date:  12-19-2010
Number of Hours:  1.50
Manual Reference:  SNX-E01
Brief Description:  More Panel Work
Well, I thought I was going to work on the panel, then I realized that I really needed to have the breakers mounted, since they were the starting point for all the panel wiring.
The breakers did not come with washers, just mounting nuts. On a prior paint attempt on the panel, tightening the breaker puckered the paint, ruining it, so I really wanted to use washers to protect. Of course, I could not find washers with a 7/16" hole that were anywhere close in OD to work.
I finally located some with 1/8" hole, so I updrilled them.
Then, I spent time figuring out the COMM harness wiring. Each headset jack assy harness was labelled, but not according to pilot or copilot. Dug out the VOM to check the pin-outs and determine which was which. Labelled correctly.
