Zenith CruZer & Sonex Logs
Sonex
SNX-T01
Finish Vert Stab Hardware
Finished installation of hard-to-reach AN3 hardware securing the vertical stabilizer aft spar to the lower aft fuselage. Torqued hardware.
Tightened and torqued the front spar of the vertical stab-to-horiz stab attachment.
Re-installed rudder. Now I can finish filing the rudder control horn to ensure 25 degrees rudder swing.
750 Cruzer Home
Sonex Home
2664
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
77
219
02 - Wing Spars
03 - Wings
119
389
04 - Flaps & Aileron
05 - Aft Fuselage
53
106
06 - Turtledeck
07 - Fwd Fuselage
114
224
08 - Motor Mnt/Gear
09 - Glare Shield
10 - Panel
43
84
11 - Windscreen
12 - Canopy
25
13 - Engine
83
148
14 - Cowling
219
Systems
389
