Worked the upper trim strip that joins the upper window to the windshield and cabin frame.
Measured and laid-out the rivet hole locations on both the upper (wupper window) and lower (windshield) attachment points. The upper flange has 18 locations, which will just be trim-to aqcrylic soft rivets. The lower flange will have 7 locations for trim screws to hold the trim to the acrylic and cabin frame tube.
Installed the lower trim strip to the bottom of the windshield, then squared-up the windshield and placed it in final orinetation.
