Installed the rear torque tube mount rudder cable fairleads. Drilled center to #20 for the rudder cables, then riveted to the rear torque tube support.
Installed the lower part of the upper door frame trim to the cabin frame. Had to pilot drill thru existing holes in the painted pieces (both sides) and into the cabin frame. Once the lower piece was drilled, the upper pieces (also drilled from factory) were cleco'd in place and all holes taken to #30 in preparation for A4 rivets.
I couldn't resist, so I just set the upper roof glass in place to help give the canvas cover some support.
