Continued scraping protective paper off of right door glass. Used goo gone to remove residue. Some scrubbing required, but after a bit, it comes off cleanly. Washed with water and dried, then followed up with plexi cleaner Prist.
Used Goo Gone on windshield to remove residue spots from it as well. Water and Prist as on the right bubble glass.
Cut covers for the trailing edge access holes I made during wing installation. Trimmed as needed and pilot drilled rivet holes. Drilled into trailing edges. Removed and painted.
