Torqued cam gear that I previously loosely attached. Safety wired 4 bolts.
Gave a final checkof everything. Aligned oil pump drive gear with cam gear. Coated all gear parts with 50 weight engine oil. Coated both sides of accessory case gasket with the copper gasket selant as per M-O manual.
Lowered case into position. Gently tapped to fully seat once I knew the oil pump gear was engaged properly. Installed and torqued 5 case nuts, washers, and lockwashers. Coated the oil screen gasket with the copper gasket sealant, laid into place, then installed the oil temperature sender cover. Since this engine has an external oil filter, the bronze screen is no longer required. Previous owner had this cover fabricated so I continued the tradition.
Installed 2 AN4 hardware sets and one AN3 set of nuts, washers, and lockwashers. Torqued to spec.
Coated both sides of the vacuum pump drive gear housing with copper gasket sealant. I left the gear out since I'm not going to use it. Installed mount. One stud was AN5 with the rest AN4. Torqued to spec.
Coated both sides of the blockoff plate gasket with the copper gasket sealant. Installed the gasket and the blockoff plate and torqued the nuts to spec.
Found some more hardware parts to clean so let them soak in solvent.
