Brief Description: Finish right vinyl decals; started left side
Put the plane out in the sun to help dissipate the remaining bubbles in the vinyl. Worked to manually fit around the rivets a few times.
Measured the key points on the right side; placed the left side grapnics in place, and adjusted several times. Taped the front portion in place, then added the aft section.
