Zenith CruZer & Sonex Logs
750 Cruzer
C75-CCO-1A
Nutplates for right side of center console
No pics.
Had to do a bit of rework in that I forgot the center horizontal piece had nutplates as well as the L angle sides. Removed L & R upper nutplates.
Installed nutplates on all remaining locations on the center console horizontal section.
Up-drilled the un-nutplated holes to allow some "wiggle room" when doing final install. This is for access only; not structural.
Installed nutplates along the botttom L angle for the console side skin. Test-screwed each after riveting.
Riveted the right side vertical L angle to the front seat support.
750 Cruzer Home
2789
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
54
273
02 - Wing Spars
03 - Wings
109
464
04 - Flaps & Aileron
123
273
125
336
113
Systems
464
Sonex Home
