Zenith CruZer & Sonex Logs
Date:  12-29-2019
Number of Hours:  2.50
Manual Reference:  n/a
Brief Description:  Install Left fuel line & pitot/static & wires
Trimmed the L-angle inside the vertical channel since I didn't bother during the construction - figured nothing was going in there Surprise!
Measured fuel sender wire & 3 conductor strobe wire to reach the panel underside. Installed it with the pitot-static lines in a second wire loom so that it was separate from the fuel line in its loom.
Applied thread sealant to two fittings and installed them into the drain "T" shown in pic 2 below.
Installed the two loomed assemblies into the aft channel of the forward vertical channel and cleco'd into place. Tightened the bulkhead connector nut on the outside. Installed the lower fuel drain thru the fuselage bottom and into the bottom of the "T" fitting.
Installed right side wires into a smaller loom since no pitot static lines on the right side. Installed the right fuel line into its own loom and zip-tied it to the line.
Still have to trim the inner L-angle as I did on the left.
thru the wall to the wing mount location
fuel line to drain & wire/pitiot-static
Underside; fuel drain & brake line tube
