In getting ready to disassemble the fwd fuse for debur and riveting, there were just a few minor task to complete.
Installed the seat pans one at a time. Installed the seat side angles that connect the seat to the fuselage sides. Several on-and-off trial fittings as there was some interference between the seat base and the vertical channels on the fuselage side (both sides).
Marked the centerline and rivet locations on each seat base angle; pilot drilled, then opened up to #20 for A5 rivets.
Painted the rightr landing gear mount; touched-up prior paint on the cabin fram gussets I painted the other day.
