Zenith CruZer & Sonex Logs
750 Cruzer
C75-FA-4
Fwd Fuse Longerons
Too much holiday prep going on....
Managed to squeeze in a few minutes on the forward fuselage longerons.
These were pre-cut to the correct length, but needed to be pilot drilled for placement along the edges of the fuselage.
Additoinally, had to trim-off angle cuts on both ends for spacing reasons.
Cleaned up the parts, clamped in place, then proceeded drilling to #40 holes thru the holes already placed in the lower skin of the fwd fuselage.
Orientation pic of longeron cleco'd in place
Just showing both sides cleco'd
750 Cruzer Home
2789
00 - Kit Arrival
00 - Miscellaneous
01 - Empennage
54
273
02 - Wing Spars
03 - Wings
109
464
04 - Flaps & Aileron
123
273
125
336
113
Systems
464
Sonex Home
