Zenith CruZer & Sonex Logs
Date:  6-14-2018
Number of Hours:  2.70
Manual Reference:  C75-WA-2
Brief Description:  Prep for riveting
Removed all skins (aft outboard, inboard, inboard leading edge, outboard, and deburrede after drilling the various fittings.
Deburred the ribs associated with the strut fitting since they had additional holes drilled in them. Deburred the main spar.
Updrilled the strut fitting and doubler to final 7/16" size using the drill press to ensure straight holes. Riveted the doubler to the angle. Riveted the one rivet hole that resides under the doubler before cleco'ing the angle/doubler assembly.
Rechecked wing level to ensure no twist.
Cleco'd all skins in place; next step is to rivet the lower skins.
strut fitting in place
ready to go
ready to go
