Brief Description: Rivet trailing edges & fuel tank top skin; prep ro
Riveted all of the upper trailing edge rivets and the upper fuel tank skin - except for the root skin edge & root rib. This skin is not riveted until final assembly prior to inspection. Bent the root skin angle to match the slope of the root skin to the root rib; this will be pilot and final drilled, but not riveted. This will take some finessing since the butt joint with the root nose rib skin is challenging.
