Made the canopy rail, this slides and notches into slots in the longerun to keep the canopy shut. As others have done I added an extra slot to keep the canopy open a little whilst taxying. This was made from 2024 and was very time consuming to make. Also fitted the exhaust tunnels using epoxy/bog and clecos to try and avoid putting strain on the cowling hinges, will add the rivets when set and sanded smooth.
