Phil Birds Web Site
Date:  12-8-2014
Number of Hours:  5.00
Brief Description:  Fitted legs
Drilled top bolts in Legs. Tubes in engine mount that top bolts go through were 6mm id, not sure if this was intentional but probably a good idea. I was concerned if those short pieces of tube were not welded in the correct position, the holes I had drilled in the legs would not line up.
Removed mount refitted legs and back drilled tube to 1/4". Cobalt drill bits, not cheap but cut through Titanium easily with cutting oil.
Legs seem really short, checked length, they are correct. Axle's next
LH Leg
LH Leg
