Phil Birds Web Site
Date:  11-1-2014
Number of Hours:  16.00
Brief Description:  Fuselage
First work that needed to be done was to fix up bulges in turtle deck where formers had not been checked for alignment before riveting. Mainly in former#3. This involved drilling out rivets inside and outside and moving the former.
Also had to drill out rivets for the same reason at the front of the turtle deck and add shimms to keep turtle deck stright. Still not perfect but better then it was.
Also found wrong bolts installed holding front to rear attach brackets, correct according to the plans but needed extra washers to stop nuts "bottoming out"
Front section
Front section
Rear section
Rear section
Formers that had to be moved
