Fitted the wing tips after fitting some anchor nuts for the strobes. Lots of filling required to get these looking right. I then tried fitting the ailerons and didnt like the way the aileron edge protruded past the wing tip on full down travel so I drilled out the aileron tip rivets and replaced the tips at a different angle. Fitted the srobe/landing light plug to the fuselage
