Drilled switch panel for switches & fuses, drilled another hole in panel for the compass. Fitted cht and egt sensors. Fitted rdac unit using nut plates Fitted voltage regulator Fitted main fuse using nut plates. Refitted the muffler onto the motor but noticed the muffler is not square with the motor, looks like the pipes on one side are longer then the other. Think I will run this past Jabiru.
