Made up the brake cables, not real sure about the nylon pulley I have on the brake lever, might have to source a metal one. Made a metal plate that bolts to the brake drum to hold the RH wheel pant, do not like the attachment method shown on the plans, took a long time to get it the way I wanted but I can now use it as a pattern for the LH side. Also had to re trim the leg fairing to get it to fit nicely against the wheel pant. The engine and Sensenitch prop arrived today from Jabiru.
