Big day today. With some help from my good friend Eddie we fitted the wings to the fuselage. The rear spar carry through was a bit fiddly but all went very smoothly really. I had already drilled the spars out to a tight 3/8 fit and with the double margin drill, drilled out the angle on the fuse. I had to grind down the rivets where the bolts come through, I will drill these out later and put them in from the other side. Only just enougth room for the nuts to go on. Next step is to take the wings back off and replace all the cleco's with rivets.
