Put tailwheel assembly together. I intend to use a Falshaw wheel instead of the one from Wicks as its lighter. A lot of stuff on a Sonex is well thought out, not so sure about the control arm for this tailwheel, its rigid from the rudder horn, any amount of flex from the tail spring must put a lot of load on the rudder horn, might investigate some sort of ball link.
