Emptied fuel and leveled aircraft. Added weight of wheel pants afterwards. Empty weight of 1106 plus 4lbs each for main gear fairings and 3 lbs for nose fairing. Total weight of 1117 lbs. Also cleaned up wiring runs from wing into fuselage and placed silicone strip to prevent chafing over time. Did not balance prop at this time since cowl fit is too tight with WW prop.
