Did not work Saturday due to Nebraska game. Did get in a full noon to midnight session with dinner break. Got under panel and added two adel clamps to oil cooler cable. Fabricated two plates to fit around stick boot from .025 2024 sheet. Primed and painted. Installed cam locks in oil inspection door on top of cowl. Did more minor filing on bottom of cowl as I found a spot that was still making slight contact from spinner backplate. Added flightline aileron push tube boots to keep air from coming in from wing root. Verified clearance for aileron trim from autopilot servo. Made a steel shim to fit between clevis on shoulder harness attach point to take up slop.
