Brief Description: Fitting of the Doors (grinding and sanding and san
SECTION 45-05
July 10 and 11th, 2010
Completed quite a bit of work this weekend, achieving the gluing a of both door shells together and then fitting into place.
Step 8, Removed the cured door after removing all the clamps and the removed all the cleos and admired my work. Step 9, Now time to repeat the above with the right door assembly.
Time should be about 14 hours for both doors.
Left Door Getting Closer to a Perfect Fit (Lots of Fitting and Sanding and Fitting and Sanding ......)
