Conrads X-10 Build Log
RV-10
OP-37 Wiring Harness
1-9-2010
OP37-6 Step 1 to 4
Section OP37- RV-10 WIRING HARNESS Page OP37-6 Ste
Section OP37- RV-10 WIRING HARNESS Page OP37-6 Steps 1 to 4
Step 1, Added a nutplate K1000-08, to the wire cover assembly.
Step 2, Carefully measured and ten drill tow ¾” holes in the F-1002-L Fwd Fuse Bulkhead and placed two SB750-10 Bushings.
Step 3, Measured for match-drilling a set of #40 holes in the side of the F-1069 Fwd Side Skin as shown in figure 3.
Step 4, Final drilled the F-1016H Guide Brackets and bored out to ¾” with a uni-bit the two Guide Brackets, primed and added two SB750-10 Bushings.
Time 1 hour
RV-10 Home
2382
EAA and FAA Inspecti
FAB
FF
FF1 Engine Installat
FF2 Cowl Baffle
Final_Kit
Flight_Training_and_
FUEL TANK Section 18
Gas_Expense
Hanger_Rent
Interior Finishing
Lights Nav and Strob
Oxygen System
Paint Empennage
Paint Fuselage
Paint Wings
Perry_Apt_Hanger
Propeller
Section 10 Tail Cone
Section 11 Empennage
Section 12 Empennage
Section 13 Main Spar
Section 14 Wing Ribs
Section 15 Rear Spar
Section 16 Top Wing
Section 17 Outboard
Section 18 Fuel Tank
Section 19 Stall War
Section 20 Bottom Wi
Section 21 Aileron
Section 22 Flaps
Section 23 Aileron A
Section 24 Wing Tips
Section 25 Mid Fusel
Section 26 Mid Fusel
Section 27 Fire Wall
Section 28 Forward F
Section 29 Fuselage
Section 30 Step Inst
Section 31 Upper For
Section 32 Tail Cone
Section 33 Baggage A
Section 34 Baggage D
Section 35 Access Co
Section 36 Brake Lin
Section 37 Fuel Syst
Section 38 Rudder Pe
Section 39 Control S
Section 40 Flap Syst
Section 41 Upper For
Section 42 Rear Seat
Section 43 Cabin Cov
Section 44 Wing Atta
Section 45 Cabin Doo
Section 45A Cabin Do
Section 46 Engine Mo
Section 47 Spinner &
Section 48 Gear Leg
Section 49 Seats & S
Section 50 Cabin hea
Section 6 Vertical S
Section 7 Rudder
Section 8 Horizontal
Section 9 Elevators
Stall Warning Sectio
Wing Expenses
