Brief Description: Section 37 FUEL SYSTEM page 37-4 Steps 5 to 7
Step 5, I have finally received the Electronics International FT-16 fuel flow transducer from Dynon. Also known as the “Red Cube”. First I make a mounting bracket for the Flow Scan to be anchored to, then fabricated a small 3/ inch aluminum tubing with AN8186D nuts and AN819-6D sleeves that attach one end of the electric fuel pump to the other end of the “Red-Cube”.
Step 6, Skip this step as it has to do with the NOT using a fuel sensor.
Step 7, I made a fuel line that connects from on end of the ”Red Cube” to the 45 degree bulkhead fitting using the appropriate AN fitting.
Time about 3 hours because I had problems with the tube bending.
