Brief Description: Tail Cone Section 10-4 and 10-5
08/04/2008 …. Added the Fix of the F-1010C Bulk Head Doublers to the F-1010 Bulk Head and final and match drill the corresponding holes with a #30 or 3/16” drill. Then Step 3 deburred the F1008 L /R Frames and attached by means of clecos the F-1085 Rudder Cable Bracket and final drill all holes in common with #30 drill bit. Now step 4 and 5 page 10-4. Deburred and fluted F-1007 L/R Frames final drilled common holes with #30 drill and using my Unibit drilled two ½” holes that need to be enlarged to 3/8” when I purchase a new Unibit drill that has the 3/8” size. Time only 2 hours.
