SECTION 38 RUDDER PETALS & BRAKE SYSTEM, Page 38-2, Step 1 to 6
Step 1, Located the F-1052A-L/R Brake Pedals and removed the hatched area.
Step 2, Created four separators as shown in figure 2.
Step 3, Located and clecoed the F-1052A-R, Brake Pedal, F1052B Brake Pedal Side Plate, and the F-1052C Brake Pedal Doubler Plate together.
Step 4, Final drilled #30 all the holes in common.
Step 5, Dissembled the brake pedal assembly, deburred, removed the alodine, cleaned with Acetone and primed.
Step 6, After the primer dried thoroughly I riveted the Brake Pedal Assembly together as shown in figure 3.
Time about 2 hours because of priming.
