Brief Description: Rear Spar 15-2 Completed steps 1 to 7
SECTION 15 REAR SPAR 12/02/2008 … Completed steps 1 to 7 on page 15-2. I removed two out of four notches in the Hinge Bracket Spacer Trim for the Outboard Aileron Bracket Assembly W-1014-L/R using the band saw. Then located two previously trimmed Aileron Hinge spacer, the W-1013C-LX and W-1013C-R Aileron Hinge Bracket sides together along with AN470 AD4 and AN426AD4 rivets. After deburring to remove the factory finish and priming as in figure 2 and 3 then assembled and riveted the same. Time about 4 hours due to deburring and priming.
