Brief Description: Wing Ribs Section 14, steps 1 too 4
SECTION 14: WING RIBS 11/23/2008 … Section 14 ... Completed steps 1 to 4 today on page 14-3 . I removed or notched a small amount ( 19/32 of a inch)of the flange from one of the W-10101 ( for both right and left sides) as described in figure 1. Step 2 required removing the aft flange but not the flange radius from one of the W-1012 Outboard Wing Ribs on both right and left. Clecoed the completed W-1010-R, W-1011 L/R Inboard Wing Ribs and W-1012-L/R Outboard Wing Ribs to the Main Spar Assy as shown on Page 14-1. Then Match Drilled using the #12 drill the upper and lower attachment points. Final-drilled the #30 and #40 common attachment holes of the Rib Flanges to the main spars. Then marked appropriately and disassembled the ribs and placed in a cardboard box labeled for the left and right wing to be deburred and then primed before final riveting of the assembly. Time for both wings spars about 6 hours.
