Conrads X-10 Build Log
Date:  6-7-2009
Manual Reference:  Section 24-3
Brief Description:  LAYING OUT THE WING TIP AFT RIVET PATTERN
6/7/2009 Section Page 24-3 Step 5 to 7. LAYING OUT THE WING TIP AFT RIVET PATTERN, step 5, I inserted the W-10016 Wing Tip Rib into the aft position roughly 2/3/8 inch from the aft end of the Wing Tip, as shown in Figure 3 Wing TIP RIB ISO View. Marked the Wing Tip at 5/16 inch for drilling #40 holes every 1.5 inches started drilling holes. Machine countersunk the #40 holes just drilled in the Wing Tip to accept the head of AN426AD3-4 rivets. Removed the Wing Tip Rib and removed the alodine coating and primed the reinserted into the Wing Tip assembly and riveted in place. Time for both Left and Right Wing Tips about 2 hours.
Added the Wire terminal for the Van's Landing Light, Duckworths Landing Light and the Navigaation Lights.
Both Left and Right Wing Tips fitted to the Wings
Van's, Leading Edge and NAV Lights +12v Power Strip
Leading Edge Duckworks 75 W Halogne Lights Complete
