Conrads X-10 Build Log
Date:  5-8-2009
Number of Hours:  1.00
Manual Reference:  21-7, Step 5.
Brief Description:  removed the A-1001 Trailing Edge from both Aileron
05/08/2009 … 21-7, Step 5. I removed the A-1001 Trailing Edge from both Ailerons and applied a thin coat of the “Pro-Seal” mixture and ten reinserted the Trailing Edge’s back into the Ailerons and secured with clecos and proceeded to weight down the Ailerons with a 2X6 and 1 gallon water bottles. After waiting about 3 days I will proceed to rivet the Ailerons. Time about 1 hour for both Ailerons.
Weighting Down the Pro-Sealed Trailing Edge
Trailing Edges of the Ailerons, clecoed and
Trailing Edges of the Ailerons, clecoed and "Pro-Sealed"
