04/05/2009 .... Section 20 Bottom Skins page 20-6 Step 1. On the Left Wing I final drilled out the 8 access holes and access cover plate holes using the #27 drill for the #8 screws then dimpled with the #8 die and added the nut-plates by means of attaching with AN426-3-3.5 rivets. Then final drilled #19 drill bit and dimpled with #6 die the 4 access holes found on the Access Covers for the #6 screws found on the Main Spar. Time about 2 hours for the Left Wing because I made a mistake and had to drill-out the attached nut-plates and correctly re-attach, only time was lost no material. However I did work all day riveting the Bottom Skins so I was a little tired.
