Brief Description: Adding the Pitot Mast to the Bottom Skin W-1005 -L
04/04/2009 …. Section 20 Bottom Skins Page 20 Step 11. Installed the Pitot Tube mast that I purchased from SafeAir1.com that will hold the Dynon Heated Pilot Tube and AOA sensor. Included with the installation kit were explicit instructions on how to mount the SafeAir1.com pitot mast. Entrance to the Dynon Pitot Tube and AOA sensor is through the existing access hole and to the right by means of a large lighting hole with-in the wing rib. The process was simple as the instructed detailed and only took about 1 hour.
