Brief Description: Aileron Gap Fairng and Flap Gap Fairing Fillet
3/21/2009 Completed steps 2 to 6 on page 20-4. Manufactured the two Flap Gap Stiffeners W-1021B L/R as shown in Figure1. The clecoed the Flap Gap Stiffeners to the Flap Gap Fairing W-1021-L Then cleced Aileron Gap Fairing W-1024-L and final drilled using #40 and #30 size drill to the Rear Spar as shown in Figure 2. After final drilling the matching components I Deburred and removed the alodine on all parts then dimpled and primed with DTS Acrylic White primer /finisher. Finally used the correct rivets called out in both Figure 3 and 4 I riveted the Flap Gap Fairing W-1021-L and Aileron Gap Fairing W-1024-L to the top skins and rear spar. Time for just the Left Wing about 4 hours.
